Aorus GeForce GTX 1060 9Gbps Overclocking
Using Aorus Graphics Engine, we initially set the power limit to 111 percent and the temperature limit to 92°C – the highest available values. We also set the GPU voltage slider to 100 percent for good measure.
With these settings, we hit a final stable overclock of 1,717MHz for the base clock, giving us a reported boost clock of 1,945MHz. This is a 110MHz increase over the out-of-box speeds, or seven percent (14 percent over reference speeds).
We also managed a clock speed of 2.475GHz on the memory for an effective speed of 9.9Gbps – a 10 percent boost over the new default speed of 9Gbps.
Palit GeForce GTX 1070 GameRock Premium Edition 8GB
AMD Radeon R9 Fury X 4GB
Aorus GeForce GTX 1060 9Gbps 6GB (OC)
Asus Radeon RX 580 Strix Gaming Top OC 8GB
Gigabyte GeForce GTX 1060 G1 Gaming 6GB
Sapphire Radeon RX 580 Nitro+ 8GB
Sapphire Radeon RX 480 Nitro+ OC 8GB
Sapphire Radeon RX 480 Nitro+ OC 4GB
Gigabyte GeForce GTX 1060 WindForce OC 3GB
2000
3000
4000
5000
6000
7000
8000
9000
Score
Sapphire Radeon RX 470 Nitro+ OC 4GB
Aorus Radeon RX 570 4GB
MSI Radeon RX 570 Gaming X 4GB
Frames Per Second
Frames Per Second
